Pressure Regulator location and fuel return?
mcg - 12/6/11 at 10:08 PM
Hi,
I am running an 8v vauxhall engine with fireblade carbs. I have a facet fuel pump that is located next to the fuel tank.
I have been told I need a pressure regulator to bring the pressure down to 1.5 - 2 psi for the bike carbs.
So, my question is where should I place the pressure regulator?
I thought I need a fuel return back to the tank but I have read on the forum that this is not necessary when running the bike carbs?
Assuming no fuel return then, I plan to put the pressure regulator in line after the fuel filter on the way to the carbs? Is this right?
If I need a return, where should the pressure regulator go and where should the return pipe come off?
I have searched alot on the forum and read a lot, but I am still a little confused!!
Thanks as always.
Matt
phoenix70 - 12/6/11 at 10:37 PM
Running Carbs, you shouldn't need a return, and the pressure reg should be where you suggested.
michael92 - 12/6/11 at 11:51 PM
you are right yeah when using bike carb's (no return) the reg goes before and as close to the rail whereas if a return is used place after the rail
Michael
