Can anyone think of an engine that has its exhaust exit on the right like a pinto, thinking of an upgrade this winter and want to change as little as
possible.
RD
Duratec!
DURATEC, and the exhaust spacing is the same as pinto, so just replace the exhaust flanges.
bmw's do.
why don't you get a BIGGER Pinto?
Get a V8, then you can have an exhaust each side
Cosworth
s2000
Puma of course!
A quick tink and the only ones that spring to mind that havent been mentioned are...
Peugeot Mi16
Clio 16v/Williams/172/182
VAG 20V Turbo
Thanks people
I thought Duratec had exhaust on the left when configured for RWD wheras Pinto is on the right ??
Edit to say just found picture of Duratec & it doe exit right ....... Thanks
RD
[Edited on 22/6/11 by rallyingden]
a nicely set up NA Cossie will see about 220bhp, MORE THAN ENOUGH!
Turbo your pinto?
Cossie?
And as above, Duratec...
(what size does 4age exit on?)
4A-GE is on the left
