Afternoon all,
I hope you're well?
Is there any chance someone could point me in the right direction for the correct polo radiator to use with a zetec please?
Also, what are the dimensions of the said radiator?
Thanks in advance,
Chris
Searching for polo and under user name "Surrey Dave" Should fine you part nos.
[Edited on 16/9/11 by Bluemoon]
Originally posted by Bluemoon
Searching for polo and under user name "SurreyDave" Should fine you part nos.
I've had a look at surrey dave's posts regarding the radiators, and I've seen the dimensions, but any ideas which mk or part number
I'd need?
Also, what is the switch for that I can see in the left hand side (from the rear) of the radiator? I've read somewhere it's for a temp
sender, but if I'm using the one already on the zetec engine I have, do I need to use it?
Cheers again,
Chris
VW4 on this web page is the answer I believe
Lnky dinky to Northern Radiators
edit bit
The thermo switch would be the standard 2 pin VW switch and don't forget to buy a VW made Gasket when fitting it. it controls the electric
fan.
[Edited on 16/9/11 by jollygreengiant]
Originally posted by ChrisLeary
I've had a look at surrey dave's posts regarding the radiators, and I've seen the dimensions, but any ideas which mk or part number I'd need?
Also, what is the switch for that I can see in the left hand side (from the rear) of the radiator? I've read somewhere it's for a temp sender, but if I'm using the one already on the zetec engine I have, do I need to use it?
Cheers again,
Chris
