Carb for 1600GT X-flow.
twinturbo - 5/8/04 at 10:04 AM
What carb should a 1600 x-flow have.. And does anyone have a cheap spare one..
TA
TT
[Edited on 5/8/04 by twinturbo]
David Jenkins - 5/8/04 at 11:21 AM
If you want a single down-draft carb then the Weber 32/36 DGAV is favourite. It's easily available, easy to set up, and pretty effective. It's probably the best choice if you're not doing much tuning elsewhere, e.g. hot cam, porting, etc.
If you want twin horizontals, then someone else will have to advise you!
twinturbo - 5/8/04 at 01:08 PM
What donor am I likly to find one from? Does it have teh correct 4-bolt fitting fro the manifold...
I have only ever had Pierburg 2e3's on my carbed motors..
TT
