Does anyone know what diff would fit in a vauxhall viva axle as i would like to change the gear ratio, Eg Morris, Mg?
rich201283 - 30/9/11 at 06:04 AM
AndyGT - 30/9/11 at 08:01 AM
Chevette cwp?
AndyGT - 30/9/11 at 08:02 AM
What ratio do you have now?
From interest, do you want to go higher or lower than standard?
rich201283 - 30/9/11 at 10:14 AM
I belive the diff is 4.125:1 - i want a lower ratio as it revs a buit high when cruising
r1_pete - 30/9/11 at 11:24 AM
The 1.6 Viva was 3.9 IIRC the 1.8 & 2.3 Firenza &Magnum were higher too
bmseven - 30/9/11 at 05:26 PM
There was a Magnum axle up for grabs the other day? Cant remember where JPSC?
rusty nuts - 30/9/11 at 06:42 PM
You mean a higher diff ratio not lower for less revs at a given speed . the numbers may be lower but the ratio is higher. A five speed box would give less revs for a given speed but it would depend upon which engine you have as to if one is a straight fit . If you are using a Viva engine I don't know of any
