low oil pressure
Valtra - 2/10/11 at 10:56 PM
Went out for a blast late this afternoon for the first time in nearly 2 months as I've been so busy working and sorting out my sons uni. accommodation .
couple of times the oil light came on which has happened before when getting "enthusiastic" round a roundabout but usually takes a lot of provocation . then to my horror I noticed the oil pressure gauge showing only 1 bar pressure , I instantly dropped the pace and cruised gently home . Pressure was fine when I first struck up and I'd checked the oil , also fine .
What's the first thing to check? oil pump? engine seems to be running free enough
snapper - 3/10/11 at 05:42 AM
Check pick up is not full of crud
Valtra - 3/10/11 at 06:59 AM
Hi
thanks , still a sump off job though! shouldn't be any crud in there but will check.
rusty nuts - 3/10/11 at 06:53 PM
The first thing to check is that you have an oil pressure problem rather than a gauge problem, test the pressure with a workshop type gauge before stripping anything.
Valtra - 3/10/11 at 09:10 PM
good point
matt_gsxr - 3/10/11 at 09:24 PM
Oil level. Sometimes it is the simple things.
Valtra - 3/10/11 at 09:51 PM
I checked before the journey but not since , will do thanks
