I bought this the same time as my axles under the impression it was off a Range Rover Classic.
I've been scouring ebay looking for a back one and seen loads of different Landy props. They all have big hollow tube construction whereas this
dude is a solid bar!
Anyone recognise it?
Is that a sliding joint on the righthand end? If so, it could be a Landy prop. I've seen a few pattern LR ones similar to the one you have.
Yes iits the sliding joint. I know its a landrover fitment as it bolts up to my axle and whatnot.
Just not seen a solid bar type one before.
Range rover classic front prop when fitted with a three speed chrysler torque flight box only made them for a couple of years thankfully then went
ZF auto.
I had a couple, the highest fuel consumption cars I ever owned, worse than a v12 XJS and slow with it.
[Edited on 31/10/11 by mark chandler]
Originally posted by mark chandler
Range rover classic front prop when fitted with a three speed chrysler torque flight boxonly made them for a couple of years thankfully then went ZF auto.
I had a couple, the highest fuel consumption cars I ever owned, worse than a v12 XJSand slow with it.
Indeed, nice to invoke such evocative memories there...
