Owww duratec v6 has arrived :)
samjc - 1/11/11 at 06:28 PM
Hi fellow builders, as stated my toy has its new engine, wont be going in till next winter at the very earliest(just a hopeful.adition to my project).
Well the reason im bothering everyone with this is im after loosing a lot of the rubbish from the engine so anyone needing parts send me a message, its from a modeo estate its the 2.5lt duratev v6 24valve. All cats are being scrapped but theirs both front suspension setups with driveshafts +discs calipers and wishbones, also the gearbox is their all the loom (going to be hell to tidyup as must be miles of wires) any advice what else to loose I know aircon pump.and all the plastics. Also once ive looked how to remove the transponder for the key their will be a steeringwheel with its shaft(not sure realy term).
big_wasa - 1/11/11 at 06:44 PM
Chip from key is easy.
If its a solid key (non remote) Then drill a small hole into the red or blue pip. Not to deep as the rdif chip is in glass. Then just prise it out the plastic bit. Chip is in a ruber sleave and will drop out.
Remote key, there is a button to depress, remote section pulls out and chip is in a red plastic protector that pulls out the end.
samjc - 1/11/11 at 07:03 PM
Excellent stuff cheers.
