locost race exhaust
locost47 - 4/11/11 at 09:17 PM
HI people done first season in locost bought mainly from ebay ,now upgrading various parts ,99% of cars on grid use the same type of headers where is best place to purchase same & possibly repackable end can thanks in advance cheers tim
ShaunB - 7/11/11 at 10:27 PM
Hi Tim - I know a few cars are using the Tony Law manifold. The one on my car is stainless and I presume came from Stuart Taylor originally. Of course you could speak to Matt at Procomp to see what he uses on his cars.
Shaun.
locost47 - 8/11/11 at 07:40 AM
thanks good idea will do
procomp - 10/11/11 at 07:03 PM
Hi
Just been pointed to this thread.
If you are just after an average manifold that will work not tooo bad then the Aires / ST one will do. It is exactly the same as the Tony Law item and no difference in performance between them, only difference is the TL one is mild steel and the Aries / ST is stainless.
However if you are after the last 2-5Hp then you need to have one made to suit the engine configuration IE have you had the engine built for mid range or for top end. There are two or three who are making them who do understand what works and what doesn't with results to show.
Then there is off course the BS brigade who make something different for the sake off it just to take your cash.
Cheers Matt
PS After all that i forgot to mention that yes we do make them to order as specials.
[Edited on 10/11/11 by procomp]
locost47 - 10/11/11 at 07:34 PM
thanks guys ,car going to dyno soon using mates headers to check on power output & range as soon as done will be in touch for new set up ,i assume you can do end can to match power output cheers tim
bazhaz62 - 10/11/11 at 09:15 PM
OI I forgot you had my exhausrt, give it back this instant
locost47 - 10/11/11 at 10:16 PM
check out ebay lol
