Should have my new OBP Pedal box fitted soon, so I now need to set up the Hydraulic Clutch.
Any ideas where I can find a clutch hose Kit with Bleed facility ?
TIA
Hi Mate,
I made mine up using Goodridge components and pipe from Rally Design they do a Kit too cost about 30 pounds either way.
Use a female bulkhead fitting hose end and the bleed nipple screws straight in
[img]
Duratec clutch cylinder
[/img]
link
[Edited on 18/11/11 by big-vee-twin]
Quick way is to use a simple short length of standard brake pipe for the bleed pipe, you can either screw a standard 10mm bleed nipple into a
standard female flared fitting (convex-concave double flare) or a better way is to screw a bleed nipple in to a Male to Male brake pipe pipe
joiner.
2 way female joiners for copper brake pipe fittings x 5 | eBay
[Edited on 18/11/11 by britishtrident]
