Is the thread on the block of the pinto for the oil pressure sender 1/8 NTPF ?
Anyone
Bob,
From memory yes (fitted 4 years ago!)
Thanks col
Bob, have you decided the problem is the sender rather than a real drop in oil pressure then?
Since i topped up with a further 200ml of oil the light now stays off,so i've decided the MK chopped pinto sump takes 4 litres of oil and
i've adjusted(cut another one) the dip stick to suit.
I have a pressure gauge but no sender,i know the make of the gauge but just wanted to know the thread size where the oil light sender plugs in.
have you sorted yours ? mines pinking like mad at 9 degs so i'm at about 11 degs but down on power now,i still a
have a slight oil leak at fuel pump like yours though
If i dont get it sorted i can see the zetec conversion coming sooner than later
I've not noticed my light coming on recently (must try taking corners faster to see if I can get it to come back on).
I'm not going to do anything bout the fuel pump oil leak til winter, there's only a small dribble coming out (for now) I suspect the problem
is the gasket that I had to cut out by hand.
