Its not a question of why atm its more a question of how, anyone looked into it already?
Transit?
i had thought about that but arent most of the new ones FWD
IIRC you can get fwd, rwd or awd. And they fitted them to Freelanders so chances are you'll find something to do the job!
Dunno how much fun it will be when you try to get it to run as all the injection bits need coding.
Land Rover Defenders have the TDCi Puma engines.. 6 gears, just like a BEC. (not quite..) Not sure how you'd work around the transfer box though.
At least it means that there's a longitudinal sump/exhaust and inlet manifolds available!
What's the TDCi block based on?
