Didnt get one with the unfinished kit I bought, will one fit in the robin hoods bay? Is it worth fitting one or should I just get an electric fan to mount on the rad?
Electric fan would be better with a temp sensor. You would need to make sure you have the viscous type water pump too if you did want to go down that route however im not sure it you have the room being honest!
Cheers Dixie. Im pretty sure I have the right type of water pump which is what raised the question.
Think you might be right about space though so electric will probably be the way to go.
