Hi all first winter of owning the car so it's off the road for a bit to get loads of jobs done on it and one is replace the rubber soft mounts on
the weber dcoe 40s as they are all a little perished
Got one of these kits from eBay Item #: 150711467838.
Basically do I put anything on the sealing surface like lithium grease ect to aid sealing and how tight do I do the nuts with those plastic/rubber
bits between the cup washers
I personly do not like those rubber washers and cups , as you can not gauge how tight or square they are tightening the carb to the manifold,
I have just bought these 160553441361
Much better !!
steve
I just bought the rubber type as that's what is fitted at the minute so assumed they would be okay
I always found the thackeray washers would break after a while, which cocks one or other carb up/down slightly throwing the carb balance out, the
rubber type last for years.
I set all the gaps between the cap edges to around 3mm (so 3mm of rubber is visible), then they're all the same and tight enough.
Ian
Cool that's that's the info I was after mate
I also found rubber washers/cups/mishabs were best. Thackery washers used to break at about 1 every 1000 miles and the plastic plate and two big O rings instead of the mishabs were dogs as well.
