Sorry, another stupid question.
The webber that came with my car appears to have a fuel in and out, where do I connect the out to? Just T it back in to the supply going to the pump?
If its a dgas you can just block it off.
R
How do I identify which one it is? There is a tag on it that says webber but nothing else made much sense to me.
You can see it in this video http://www.youtube.com/watch?v=o0xAkxbJGXA&feature=youtube_gdata_player
It doesn't matter which you use/block, they are common and before the float valve.
Brilliant cheers. Makes life easier then.
They are not the same, at least the ones I have seen, there is a brass restrictor in the return side so that fuel doesn't wizz past the carb and not bother going in. If you connected the inlet on the return then you probably have problems with fuelling at wot. As has been said just block the return side.
Thanks dingz. If that's the case how do I identify the return side?
Appologies if I've mis informed, I can see the reasoning, I've had several DGAS' and not noticed a restrictor.
Would it be a through fitting used when you install more than one carb fed by the same fuel line?
