Just secured a 3.9 sierra diff, lobro type with viscous limited slip. I have a 4.4 crown wheel and pinion to fit into it. Considering fitting a titan
lsd instead of viscous. Going into MK race /hillclimb car (duratec) fitted 3.9 pumped viscous) . Whats involved in the process of pumping up diff to
stifffen it, can I do myself ?
Has anyone used Titan diff ?
AJW
MK INDY R
Ireland
Try this one
http://www.locostbuilders.co.uk/viewthread.php?tid=157337
Originally posted by Xtreme Kermit
Try this one
What I need is details of the silicone fluid and details for modifing lsd oil pack. Has anyone done this process of pumping diff
Nope, dispute what Rich says, by the time the booze wore off I had lost the urge...
Just found the viscous fluid is Dow Corning 3-9162 viscous fluid , next problem anyone know where I can get it. I understand I replace bung in lsd
unit with grease nipple and pump fluid in. Might be easier to throw unit out and replace with plate diff
ajw
If you do replace with a plate type i'd be interested in the viscous unit.
