Ive seen alot post poining towards the use of a Capri clutch cable, however this looks quite short and the installs ive seen have been with a floor mounted box - but my Striker has a top mounted box and im wondering if the extra distance to reach the clutch bar on the type 9 (which i beleive is low) will be too much. Are the install pictures ive seen deceiving me, or should I use a sierra cable which seems longer (possibly too long?)
I went to the local motor factors and bought 3 that were different lengths. Used the one that was the correct size and then took the other two back and got my money back.
