Evenin!
I've mentioned previously that I can't find an off-the-shelf bellhousing to mount the Rover KV6 longitudinally for RWD.
Then I saw a Getrag 283 gearbox (MG ZT - KV6 box) on eBay for £15 and wondered if I could split it in half and use the (slightly machined!)
bellhousing face with a backplate that suits whatever gearbox I eventually want to use.
I've removed all the bolts and managed to prise the gearbox slightly open, but the bugger won't split completely.
What am I forgetting about!? Is it the diff bearings that are holding it together? Does it matter if a gear is engaged?
And lastly... what about the general idea of using the front casing as the basis for a RWD bellhousing?
I used a Getrag front casing on my Conversion. So it can be done.
Steve.
Fantastic love it when people take like that by the balls.
Good work Steve!
... how the blooming heck do I get the box apart!
isn't that basicaly what owelly did to fit his pug V6 in the plastic car...
You will have to strip the whole gearbox I reckon, mine came as just the casings so I did not need to, I am sure its not difficult.
Go for it. .
Steve.
Selector mechanism will need to come off for a start
If it's like the PG1 gearbox there is a plug (2" diameter roughly, uses a sump plug alan type tool) on the end of the gearbox. Remove this
and there is a large circlip that needs releasing to split the box.
Page 7 of this guide.
http://www.roverklubben.se/uploads/text2907.pdf
Larger bottom plug.
...found owelly's old thread (eventually)
http://www.locostbuilders.co.uk/viewthread.php?tid=145416
Cheers guys!
I suspect it is these two bearings that are holding me up... anyone know how to remove them (before I get the grinder and a sledgehammer ).
I found when spitting a PG1 it was the gear selector mechanisim that stopped it coming apart.
