I'm in the process of putting together my GSXR TB's on a ST170 manifold. Obviously I need to blank off one of the sets of injector holes. I
know the norm is chemical metal, but I would like a removable solution in case I ever decide to got to staged injection or wish to change the injector
location (testing on a RR for example).
Is there an off the shelf "injector blank' that is available or do I need to have something knocked up on a lathe?
I have a spare set for GSXR 600s if interested....
Drop Flakmonkey a U2U... I'm sure he could sort you out!
Never use chemical metal. I learnt the hard way when the slug was sucked out of the throttle bodies and into the engine, resulting in bent valves
Wow quick response thanks
Wombat you have U2U
u2u back.
Have a look at my pictures to see what they look like....
apparently raceline do the blanks.......
i couldnt find them when i was looking for them
mine are quite a close hole size for a bsp thread, so i tapped mine up and pu bungs in
no good if you want to re-use them though
Not a problem if the slug is shaped so that it can't be sucked in. I filled mine to the lip on the injector ports - on the GSXR1000s this gave a shaped slug.
