any ideas the correct clutch plate for the rwd redtop to type 9 ?? thank you guys
Clutch plate from a 2.3l diesel sierra is the one.
Here you go
Clutch Plate
From memory on mines as said 2.3 diesel sierra friction plate. Std redtop pressure plate and very vaguely a release bearing from a ford. DO NOT forget the spigot bearing as well.
thank you soo much guys really big help
is the p100 diesel clutch plate the same anyone ???
Does it have to be a 230 mm what about the 240 mm ???
