I have a silvertop zetec running on a MS2 extra efi system with zx6r throttle bodies. Have the car up and running and brought it for a few test drives. (Idles and starts perfectly). The thing is under heavy acceleration from low rpm it seems quite sluggish to go. I have a wideband lambda sensor installed and Air fuel ratios across the MAP seem ok between 12- 14 : 1 average. I am wondering if it is more likely to be a problem with the acceleration enrichment setting which ive already had a play around with or is it more likely to do with the spark advance setting which i Haven't touched at all? Any suggestions / advice would be very welcome!!. TA
Im running lumpy cams but i'l show you my AE settings, can you show me your cold start and after start enrichment settings as mine seem to be a bit off
it will most certainly be the timing holding you back.
put a screen shot of your spark timing table up so we can see what kind of values you have in the table.
[img][/img]
Here's the spark table, as ive said I haven't really touched this since ive managed to get the engine up and running so im really not sure
what way its set.
[img][/img]
Originally posted by aidan46
[img][/img]
[img][/img]
I would suggest that's too much timing at full throttle low rpm, you want 12 at WOT upto 1500rpm, ramp up to 28 at 4000rpm, 30 after 5500rpm.
Aim for 12.5AFR WOT, 13AFR will do but NO leaner
A stock 2.0L should make 170BHP on jenvey 45s with this timing and fuelling assuming the exhaust system is big enough, 1.5inch headers minimum.
Cheers Dale.
That's Great Dale,
Gonna give those settings a Try and see how it works. Ill let you know how it goes.
