R1 carbs
loughlin1 - 1/3/12 at 06:30 AM
Hi aLL
Have got the R1 carbs fitted now but how do i get the fuel pipe on to them any help would be great
The Venom Project - 1/3/12 at 07:46 AM
What year carbs are they?
Mine are 2000 ones and have fuel coming in from the rear
loughlin1 - 1/3/12 at 11:25 AM
mine are 1999 and i do see a small pipe coming in from the rear BUT i also see 3 other little pipe inlets or what i think are inlets as well should they have little pipes on as well
The Venom Project - 1/3/12 at 01:13 PM
I know on mine they are vents, it only has 1 fuel in port, let me see if I can find a good pic of my carbs to show you where it will be as your carbs will be the same as mine:
You see where the black pipe comes from the crank case up to the airbox? This is just a breather pipe for emmisions, just to the left of that is a rubber pipe going into the back of the carbs, this is your fuel inlet
loughlin1 - 1/3/12 at 06:15 PM
YES that is super many many thanks for that
