I've been doing a bit of reading online (can be quite dangerous) about the timing on a pinto engine. I haven't checked mine yet, just
wondering on the process. From what I can work out my idle advance needs to be 12 degrees plus. Then I'll have too much max advance. I have
come accross articles describing dismantling the dissy and modding the advance stop and changing the springs to alter the timing curve.
My question is am I likely to bugger the dissy if I attempt this? Have many of you done this or just gone for the megajolt solution?
Cheers.
Have a look at Dave Andrew's site. See 'ignition timing for modified engines' page...
http://www.dvandrews.co.uk/
It'll be a case of patience, and trial and error.
Excessive advance can kill an engine, but you can check it with a timing light easily enough.
Thanks, that's one of the articles I read, I (think) know the theory, just worried about doing it and busting my dissy. From those that may have
done it, is it difficult to take the dissy apart? Maybe a practice run on a spare dissy (if I can find one).
There is an article on the NW Hoodies web site that may help.
What you want to do is set static at 12 degrees detach vacuum advance then run up the engine and with a timing light find max advance.
Your aiming for 36 to 38 degrees at 3600 rpm.
There are stops in the dizzy that can be bent in to stop maximum advance
springs can Be bought that are weaker allowing max advance early, you may need this as you are effectively steepening the advance curve.
I have fitted an FR32 cam and now an RL31 both need a higher static advance and a steeper ramp but I fitted Megajolt soo much easier to change the
advance curve.
I had a quick check last night at the timing as my new gun arrived. Timing at tickover is 8 degrees (standard spec) but max advance stopped at 28.
I now have the idle advanced to 14 and max is hitting 34. Maybe the dissy has been modded before??
Max advance is still over 4,000rpm tho, I haven;t tried to change this yet.
Originally posted by BaileyPerformance
All Pinto we have tuned like between 34 and 36 deg of timing (TOTAL). the stock dizzy does just about do the job (assuming its a late one) Disconnect the vacuum and LEAVE DISCONNECTED (do not use again)
Running with no vacuum advance really hurts fuel economy. For a road car some kind of load sensing is a good idea for ignition timing.
My vac advance isnn't connected to anything and I cant honestly see anywhere it could be. I'm not too worried about economy (within
reason), my daily driver gets me 19mpg on average so I'm used to it.
I'll get another look at it over the next couple of days, thanks for the advice.
My vac advance isnn't connected to anything and I cant honestly see anywhere it could be. I'm not too worried about economy (within reason), my daily driver gets me 19mpg on average so I'm used to it.
