boost controller
beaver34 - 17/3/12 at 05:39 PM
im going to run a electronic boost controller on my car, wanted to find out how much more boost you can run with them over the stock wastgate spring, is there a limit or could you have a 7psi spring and run 28psi using the ebc?
thanks
froggy - 17/3/12 at 09:20 PM
rule of thumb is to set the wastegate to hold just under 1/2 the peak boost you plan to run with a solenoid
Antnicuk - 17/3/12 at 10:03 PM
^^^^^^ thats the basis i have always used.
matt_gsxr - 17/3/12 at 10:54 PM
Agree with the above.
If you try to get too much boost with a weak spring, then the forces on the wastegate from the exhaust gases can open it.
kjouk - 18/3/12 at 07:40 AM
I have got away 2.5x ok, 8psi wastegate with 20psi peak boost on a td04.
froggy - 18/3/12 at 09:15 AM
The other thing to remember is actual rate depends on actuator size too , on one turbo I used it needed an 18 lb spring to get 14 lb base boost but you need to be a little below 1/2 to allow for overshoot when mapping
