Hi does anyone know of somewhere cheap to buy some piper cams for a 2.0 blacktop as I had bought some second hand but it turns out they are the wrong
size probably for a 1.8 or even a 1.6.
I have looked at places like Burton but they are a bit too expensive at the moment, any suggestions would be welcome.
[Edited on 23/3/12 by AndyG]
I don't have any, but have you considered Kent or Newman cams? you may be able to find cheaper cams if you broaden the search.
I already have some piper verniers so I thought I should get matching cams but I had considered Kent but they are coming out at similar price to the
piper's. I don't really know much about Newman cams I will have to look into how much they are.
There shouldn't be a problem mixing piper verniers and other cams. As long as the verniers you have are made to fit standard camshafts to (i.e. plain with no locating nobbly bits)
