Has anyone made a extention to move the gear lever back on a type 2 gearbox? I was going to have a go at fabricating my own but its a push down reverse so im not too sure what the best way would be.
Might be worth dropping David Jenkins a u2u
Or look on his www:
http://www.lathyrus.eu/
under 'special tools & parts, Ford 5-speed gearbox extension
[Edited on 3/4/12 by Daddylonglegs]
There are some pictures in my archive of the remote I made for my four speed type 2.
Thats brilliant David did you use parts from another vehicle for the pivoting part at the back
Thanks. I chopped down the type 2 gear lever screwed into the gearbox and modified that. I removed the reverse detent from the gearbox. I used a type
9 gearlever bolted to the chassis with a homemade detent bolted to the underside. I've seen a few variations of this, but I did mine this way
because I wanted it all to fit inside the transmission tunnel.
