Hi all
Got my striker back today after having dry sump fitted,
But due the pump location and the fact when the engine was made originally it was not at the correct angle I think to clear the bonnet,
But now it is at the correct angle it hits the bonnet, grrrrr,
But the rubber engine mounts it is on a quite tall about 40 mm I think,
It's on a k series engine,
I just wondered if any one new a good place to get engine rubber mounts that may be lower,
Caterham do them at 27 mm but are £19 each seems a bit steep?
Link to the caterham one to give you and idea what I'm looking for but mo locust if poss,
http://www.caterhamparts.co.uk/search.php?orderby=position&orderway=desc&search_query=Rubber+engine+mount&submit_search=Search
Thanks all if I cant get any i will have to get these I suppose,
Sean
[Edited on 18/4/12 by INDY BIRD]
You can afford to have a dry sump fitted but £19 for an engine mount is steep?
Thats why I'm now penny pinching as it took all my money to fit it,
Any helpful comments welcome,
Anything to do with my finance please keep well you know where,
Thanks all
What size are the old ones? Can you refit them at all?
eBay item number: 160770631625
Should be others on ebay for machine and boat engine mounting
hi sean
rally design sell rs2000 mounts in 50mm and 30mm i think m12 thread sticking out both ends
http://www.rallydesign.co.uk/product_info.php?products_id=7218&osCsid=eke36lluvc8aorapksh45qro91
striker-4age
They are jag e-type mounts. I got genuine ones from one of the suppliers a while ago, about £12 each. Cheaper available, but genuine stuff is always better value.
Thanks guys great help,
They are fitted currently and are m12 40mm high so 30 mm would be good,
Thanks again great help
Sean
1x AUSTIN MORRIS MINI ROVER MG REAR REMOTE ENGINE MOUNTING CLASSIC CAR BARN FIND | eBay
