Hi all
Another question for the guys fitting/fitted a duratec to their cars
I have the raceline oil filter adapter, and am looking to fit an oil pressure sensor with 1/8 npt thread
The raceline adapter doesnt seem to have the same thread as the original pressure switch either.
What have other done to fit a pressure switch and sensor to their Duratecs?
Patrick
I used an adaptor M12 to 1/8" IIRC which I purchased from ETB along with the digidash.
Thanks Neilp1
Did you bother fitting a oil sender to control the light on the dash or did you just go with the oil pressure gauge?
The thread is 12mm x 1.5, I bought a pressure switch for a Lotus Elise which had a higher pressure switching point to give earlier warning and an adapter.
im also considering one of these
oil light switch
given the option of 15psi and 25psi
which should i go for?
A standard one is rated at around 5-7 psi, the Elise one I have is rated at around 20psi if I remember correctly and does extinguish the light when
ticking over.
Trying to find the details of the switch now.
The operating pressure of mine is 13PSI but I cant find where I got it from, that 15PSI one would do the same job.
Thanks very much for the help
Think Ive sourced all the parts ill need now
