Hi janes gearbox again it,s a nissan primera started jumping out of 5th now wont take 5th at all any ideas
Cheers Ali
If nothing is wrong with the linkage or the engine mounts then cheapest way to fix it will be a secondhand box.
The RB, CA and SR all use the same gearbox apparently. I don't know if the ratios are exactly the same. It needs a rebuild at least, if you don't want a second hand one.
