hi guys im after a little help i have the megajolt all up and running perfectly but am going to be adding the aux input connection to the coolant temp
sender so i can have the warm up advance and i want a temperature based output
i dont have any of the aux installed yet but tried changing the settings on the software but it wont let me change any of the temperature based bits
like advance correction the boxes wont let me select them
also when its all installed how do i set the maximum and minimum perameters on the software of the temp sender
its a megajolt v4 about 2-3 months old
thanks in advance
