I've finally booked the rolling road for a full tune! Excited.
Although I have to wait till next month. Friday 13th July ! Hopefully that's not bad luck.
Getting it done at M-tech so expect a report on how it gets on etc.
Vauxhall c20xe on GSXR throttle bodies running ms2
Still need to check that nothing leaks/pops off at full temperature and change the fuel pressure reg to something not cheap and nasty.
Wish me luck !
Hi Ben good luck will be interested on how you get on as I still have had no luck getting hold of Dale @ Bailey.........
Gulp! I will never do that again...
If it's your first visit make sure everything is tip top, because after my experience, once the engine had lost its vital oil pressure, it was
done.... and that was a £4000 mistake.
All the best though, I know i'm not on my own and that plenty of RR's work out for the best, But I will never make that MISTAKE! again.
