I'm hoping someone can help, i'm in the process of converting a Coventry Climax FWM to automotive use, and am trying to find a suitable
flywheel. I know i can have one custom made, but i'm trying to possibly find something that already exists. The Climax crank has a 6 bolt
pattern on a 2 3/8" PCD, the bolts are 5/16" UNF but the holes in the existing firepump flywheel measure 0.320" in diameter. Can
anyone help?
Thanks,
Rod
Hows about the Hillman Imp? Does it not share the same engine?
The engine is similar in construction and layout, but from what i've found so far, they share very little in terms of parts. I had a look online
in regards to the Imp flywheels and they appear to be a 4 bolt flywheel for the early ones, and a 5 bolt for the later ones.
Here's a pick of the FWM:
