cn anyone tell me the pinto timing settings its a 2.0 on bike carbs if that makes any difference ?
thanks in advance
Dot on crank pointing straight up (tdc) marks should line up with a mark on the block
Dot/Pointer on cam straight down, again marks will line up with a mark on the head
Rotor arm on distributor to be pointed to a line marked on the dizzy body
the pinto is as simple as it gets....
[Edited on 30/6/2012 by Hector.Brocklebank]
sorry i meant using a stobe light
thanks
Standard cam unleaded about 8 degrees
Performance cam manufacturers setting usualy 10 to 12 depending
36 to 38 degrees all in at 3600rpm
thanks snapper will set tmos to 8 degrees btdc
