Hello all,
i have problem with the pin under position 5. It is very loose and if falls from the engine/gearbox vibration. Can i put a bolt there and secure it
with nut or should i look for another solution? Any ideas? I think there should be some gaitor there - does it cover and hold it?
pin problem
Thanks in advance
Yavor
[Edited on 5/7/12 by i_froloshki]
Hi there, interesting you say this as I had the same problem but only remember now you mention it. I think I just tie wrapped it!!! I have done 1500
miles in it so no probs. if you find a better solution let me know.
Are you mounting it to a zetec?
There is a wire clip that goes around it. You can see there is a groove that it sits in. Will see if I can find a photo.
GBS do a replacement part much easier to change than the standard ford one
if its the pin that goes through the gear selection rod..?
i bought a new lever a carriage for mine fron ford, a it came with a bolt a locknut
