So I'm getting a new can on my MK and will need it re-jetting and some rolling road time. It's fireblade engine on carbs.
Last time I used Holeshot as they were just down the road in Bradford, but they're in Ireland now which is a bit of a trek! What other options
are there coming from Leeds? Bogg Bros would I assume be the obvious choice, but are there others to consider that do bike engines?
Daytuner - just outside Harrogate.
You won't go far wrong with Damien - top bloke and knows his stuff
+1 for daytuner not used yet but have mates who have been there and i will be taking my mk there in a fiew weeks
+ another for Daytuner, he as the patience of a saint and will transform your car.
Closer and well regarded. Guess i'll give them a call then Cheers all.
Daytuner again, did a fine job on mine, came away a different car.
Thanks for the tip all. Just got back, did a great job - car running sweet now. Oddly it was running rich, not lean as I'd have expected
putting a less restrictive exhaust in. It is a different engine though, so shows how you can only really tell if things are setup correctly by a
proper tuning session.
What I did find out is that it'll run happily with or without my airbox, with the airbox just throttling slightly lower down the torque curve.
So I can have noisy for road, and quiet for track if needed
