sourcing a clutch
mcramsay - 13/8/12 at 01:06 PM
ive been having clutch slip problems since getting my kit on the road, i did have a gearbox oil leak and im thinking ive goosed the new clutch on the zetec, im looking to take the engine out this week and replace the release arm, bearing, do a modification on the type 9 release arm pivot pin to correct the geometry. and i think i may aswell change the clutch while im at it just to eliminate a contaminated clutch from causing me the problems. the engine is a bog standard 2.0 crate zetec engine, with standard 2.0 flywheel and clutch, would this be the correct clutch to replace?
Ford Mondeo MK1 2.0 16V MTX75 New 2 part clutch Motorquip 08/1994-08/1996 | eBay
if not does any body know the correct part number that i will need/ have an ebay link they could post up to help me find it.
rost - 13/8/12 at 02:42 PM
you can look through the Luk catalogue here:
http://toc.luk-as.de/toc/enter
A type 9 has a 25.4x23 type spline, although luk lists it as 26x23. I guess they don't know how to write in imperial
