I built my YB to run fast road NA, has approx 11.8:1 CR but I stuck an eaton on for the craic, pushes 5psi and the timing has been retarded way back from na setting to 18 degrees from 4500 to 7500 rpm to avoid pinking, but it seems to boil coolant every time i give it some prolonged beans, especially in higher gears .. can potter about with no probs but any hard right foot and its a jacuzzi under the bonnet. My guess is the timing being that retarded is causing hot spots around exhaust valves and boiling coolant?? or am I getting the wrong idea all together!? pointers please. Ta
Might not help being too retarded. Also, if you push 5psi you're pushing 1/3 extra power so you have 1/3 extra heat to remove. TBH I just
wouldn't bother boosting a high CR engine because they're generally very hard to get right on a budget due to the very high dynamic CR. That
said, good luck!
[Edited on 14/8/12 by coyoteboy]
Are you sure it's not just the head gasket that's gone and the extra power/boost from the super charger has finished it off? (or making it
obvious).
18deg timing isn't that low to cause any issues.
Ian
You may be right but I checked with a rad pressure tester and its holding its pressure..? tested on hot and cold engine. I might get the lend of a CO2
sniffer test aswell, will do a compression test too.
would my head gasket be under a lot of strain with upped CR and a 5psi of boost?? more so than a standard YB cosworth with low CR pistons but more
boost??
[Edited on 15/8/12 by Craigorypeck]
Not really more strain, but if the gasket was a bit marginal before fitting the supercharger, then the extra cylinder pressures would make it worse.
Quite often a gasket that's only just started to go will only really leak when under maximum pressure/load (ie, giving the car some stick) and
when driven normaly will seem fine. Over time the problem gets worse and water being blown out happens on less throttle.
Which head gasket is fitted now?.
Ian
Hi, there's a reinz standard yb one In, from buttons I think, looked like decent item with metal between the bores.
I know the one, as it's what i used to use on mine.
Absolutely fine until you start hitting it with some extra power, in my case nitrous (over 100bhp extra). When it had gone, it would be fine running
around normaly, use nitrous and it would empty the water out on the floor. I found they'd last 2 or 3 rwyb meetings and then start blead pressure
into the water under full load. I always found that they'd not blow as such with a chunk missing, but there would be spider legs (for want of a
better description!) from the cylinders leading to the water jackets.
I've now been using a Cometic mls gasket for a few a years now, with no coolant issues at all since.
Ian
oh dear, you could be right enough, also getting what I'd call more than enough vapour from the crank case breather too. Are you using nut and
stud head bolts??
also are those cometic ones the 5 layer metal jobs??
[Edited on 16/8/12 by Craigorypeck]
Originally posted by Craigorypeck
Are you using nut and stud head bolts??
yes accralite pistons and I'm using halfords 15-40 semi synthetic, i was under the impression their oil was as good as any others because of
strict consumer protection?
do the multi layer steel ones need a particular finish on the mating surfaces?? ie could i just whip off the head give it a clean and thro a multi
layer in and it will work as should??
Halfords oil to the correct spec is perfectly fine, but if you're over-stressing the engine comparend to standard operation you might want to
consider a better rated oil, and maybe change of weight profile etc. If you're regularly seeing higher running temps than in normal operation
your oil could be losing too much viscosity, a higher weight on the top end should help, but bear in mind that oils with a big weight range tend to
die faster (the polymers used to ensure the large viscosity range degrade with heat and age).
As for MLS - they're less forgiving than normal gaskets - you want the surface CLEAN and you want to ensure the mating surfaces are true to the
spec suggested by the gasket manufacturer, not the engine manufacturer.
[Edited on 16/8/12 by coyoteboy]
Ok, thanks for that, will get on it soon.
I would say 18deg is still alittle bit too much timing, i know your not running much boost but the high static CR will bring on the det quickly which
you cant always hear in a noisy car.
As stated before i wouldn't think the retarded timing is effecting the cooling system, i have seen 550bhp ybs at 4-6deg timing without
overheating. (but with big ally rad)
If the engine has been run with mild det it could have damaged the head gasket causing your problem, from past experience the stock yb gasket (we only
used Ford ones) is good for 25PSI but at standard CR. Ignition timing was around 8 deg at max boost. 16deg at idle.
Does the car seem slower at less timing?
What is your AFR at full throttle?
What is the engine temp when it starts to boil?.....do the hoses seem hard?
Hi there, The temp gauge goes up but not a lot, i do have the temp sender at the rear of the engine where the coolant comes in after the heater box,
not the best place for it tbh as is not a real indication? hoses are hard after a run.
Afr at full throttle is around 12:1 never leaner.
I did tune the timing myself whilst driving and there was some pinking but never sustained, always backed off and lowered, but still it did receive
some pinking time in the process.
I think its defo a gasket issue
Block is cracked in 2 places, water is getting to oil.
Wanted 205 block!
maybe this is the time to upgrade to one of those fancy motorsport or alloy blocks that burtons sell
Aaaaaaaaahahahahaha! with the amount i can spend it might get a standard 2.0 non 205 block @ >£50
Aaaaaaaaahahahahaha! with the amount i can spend it might get a standard 2.0 non 205 block @ >£50![]()
I know the post is a few months old but nobody really answered the question origianlly.
Any of you tech gurus have the definitive naswer.....can you boost a high comp engine,say 12 or 13:1?
Its seems that potentially yes but the risks and chances of failure are high.
I'm running 11.5:1 with 15psi at the redline. Zetec with a Rotrex
I should say that 15psi comes out of the Rotrex but only 9psi arrives at the plenum as 6psi is eaten by the intercooler (which is rubbish I know). The car makes 300HP/250 ft lb at the wheels.
Originally posted by BaileyPerformance
Decent engine such as a cosworth YB the head design is very good as standard, so the engine will make good power at low boost pressures, as the boost pressure is increased (in the hope of gaining more power) the law of diminishing returns comes in, for example a stock YB will make around 270BHP at 15PSI but it will not make 540BHP at 30PSI (without further breathing mods) so it is clear not all the boost is finding its way into the cylinders.
Do you not have to consider that 15psi is actually 15psi above atmospheric (as at 0psi boost engine will still make power) Therefore you are going from circa 30psi total to 45psi total. Gives power of about 400bhp which probably isnt far off what a cossie makes on 2bar?
Your probably right, a cossy would make 400BHP ish at 2bar, but that's what i said - 30PSI (2bar) it would not make twice the power it did at 15PSI (1bar).
The term "boost" infers extra air over an above what the engine can pull in on its own "naturally aspirated". I good race engine will achieve a VE of 95%, F1 maybe over 100% due to cleaver ram effect, average production car engine probably around 80%. The higher the VE the higher the effective compression and more power. So its not true to say 15PSI of boost is actually 30PSI as that would suggest the engine has a VE of 100% before you turbo charge it, which is not likely.
Boost is always quoted gauge not absolute - but the engine management measures absolute (MAP) as it needs to read vacuum for load purposes when off boost as well as on boost.
At 0psi boost the engine is making around 130bhp. You are increasing the mass of air by 50% so the power should increase by 50% as well not 100% as your post reads.
There will be losses whether its is FI or not but I think that talking about VE is just over complicating something that doesn't warrant it.
Thats really really good power for that boost, you must have decent cams to make that sort of power. We see around 330BHP (at engine) at 20PSI but that's with stock head and cams, we normally see more torque than power (this is due to the stock cam profile)
As you say the intercooler seems to be dropping alot, but a cool charge maybe worth more to your engine than boost, considering you have a high CR.
On a zetec a 10deg drop in air temp is worth the same as a couple of pounds of boost, so if you replaced your intercooler with a free-flow version the chances are the boost would go up and so would the air temp, you could end up with less power!!
Have you got the cam spec please? just out of interest.
Thanks for that, i'll have a look.
Your using stock pistons? the standard Ford items? that surprises me.
I think the most we have seen out of a NA 2.0L zetec is about 190BHP at the flywheel, so you are doing well to get 190 at the wheels - that must be at
least 210 at the engine? did your tuning give you a engine and wheel printout?
NA was stock pistons and rods...it now has forged pistons and rods as you would expect as well as ARP studs.
