My 1.6 sohc pinto which I got for free, sounds rough and low on power.
I did a compression test and got the following results
cyl 1 =7bar
cyl 2= 8 bar
cyl 3= 0 bar (didn't even move the needle)
cyl 4= 7.5 bar
after a couple of squirts of oil I got these numbers;
cyl 1 =7.5bar
cyl 2= 8.5 bar
cyl 3= 0 bar (still didn't even move the needle)
cyl 4= 8 bar
Haynes says the compression should be 11 to 13 bar. Obviously a serious problem in cylinder 3. Can anyone diagnose what is probably wrong with this
engine?
I will be taking the head off tomorrow, what should I look for in terms of damage, aside from the obvious (gasket). I've never done any work on
the inside of an engine before.
How much cylinder head rebuilding work can I do in my garage without specialist tools?
Before you remove the head are the valve Clarence's set right on no 3 not to tight .
After that its head off and check the valve are ok you can do a quick check by turning the head up side down and putting petrol in the head to see if
the valves are ok or leak [ over night ]
After that its piston rings or even a re-bore
I wouldn't worry too much about the actual figure, that fact 3 of them are close sounds OK (within reason, I am sure some people will
disagree).
But the fact no.3 shows nothing means a major loss of air. So I would first check the plug thread. Its possible its been threaded. You can helicoil
it, but thats big,.
It could be blowing past the rings, but the oil usually gives a reading if this is the case.
So I suspect you have a hole.
Hard to say with no's 1,2+4. Did you have the throttle wide open as not doing that could give those readings. Otherwise could be poor seals on
the valve seats or poor piston rings.
No3 is fooked! Either holed piston or burnt out valve (usually exhaust). Slight chance of a badly cracked head. If it's not likely to be gasket
with a zero reading. Id it;s the valve you'll feel very strong pressure pulses from the exhaust if you hold your hand by it. If its the piston
then the pulses will be evident holding your hand over the oil filler. If it's a (big) crack then you won't know 'till you get the head
off.
Originally posted by balidey
I wouldn't worry too much about the actual figure, that fact 3 of them are close sounds OK (within reason, I am sure some people will disagree).
But the fact no.3 shows nothing means a major loss of air. So I would first check the plug thread. Its possible its been threaded. You can helicoil it, but thats big,.
Originally posted by ReMan
What engine is it?
What brought you to be checking these figures at all?
Did it break on you or was it bought like this etc etc?
After that its head off and check the valve are ok you can do a quick check by turning the head up side down and putting petrol in the head to see if the valves are ok or leak [ over night ]
After that its piston rings or even a re-bore![]()
head off and upside down and fill with fuel.
With zero pressure on that cylinder I suspect it'll be obvious what the problem is once the head is off. My money is on a valve looking like a mouse has eaten a chunk out of it.
the mouse might have nicked the entire valve with that reading
I don't think you will need petrol to find the leaky valve...
Either a holed piston or a chunk missing from the valve or possibly a bent valve stem causing it to stick open. I don't think even MISSING piston
rings would leak that much air.
Take the head off and have a look and don't forget to let us know what you find...
To have no compression at all suggests a massive failure.
Possibilities are: Valves failing to open - possible but unlikey, Valves stuck partly open/dropped, quite likely, hole in piston also quite likely.
Poor plug threads and head gasket failures are likely to cause very low rather than no compression or the gauge needle dropping quickly to zero.
Either way it sounds as though you have a significant problem.
Plug out of cyl 3 and lower in and led ( or small bulb with wirng soldered to it ) connect to battery to light it up, look through the plug hole
whilst moving the crank by hand and you should see any piston damage.
As for leaky valves the you get a leakdown tester ( made my own from an old sparks plug ).
Does sound like you have big problems though on cyl3. You don't HAVE to take the head off to find them BUT 99% sure you'll need to have it
off to sort the problem out.
Thanks everyone for all the advise and input.
adithorp said;
It helps to have a valve spring compressor , you will need at least a valve lapping tool and some lapping paste .You may find that the valve seats need recutting once the head is stripped any decent engine reconditioneers will be able to do them for you. Once the valves are lapped in and the head reassembled it helps to have a cranked spanner to adjust the valve clearances but if you adjust them before refitting the inlet manifold you can get away without one. You will need a torque wrench and possibly a splined bit to fit the head bolts depending on which ones you have
