bike engined gear linkage kits
daniel mason - 20/9/12 at 07:39 PM
is there a place which sells stick shift gear linkage kits for bec's? i dont think i have enough room behind the wheel for a paddleshift,so i think ill go stick shift! cheers. i have seen them on the westfield site but was unsure of anywhere else.
Doctor Derek Doctors - 20/9/12 at 07:54 PM
I used a bastardised MK linkage.
Although its only a couple of rods with some rod ends and a rocker and the lever is just a welded bit of tube and plate so you can make one quite easily.
T66 - 20/9/12 at 08:26 PM
Daniel - Ive got an MNR column & paddle in the garage if your interested. Its been slightly cut around the top rim, but the collar still fits nice and tight, grub screws still tighten etc. No cable etc...
Stands me £100 -
£80 delivered ? (Scootz your rubbing off on me)
If it doesnt fit cover my post and send it back.
[Edited on 20/9/12 by T66]
daniel mason - 20/9/12 at 08:38 PM
that defo wont fit ivan. thanks for the offer mate!
T66 - 20/9/12 at 08:42 PM
no worries
wylliezx9r - 20/9/12 at 08:42 PM
I bought my kit off Aries and slightly adapted it for my car. Was reasonably priced too.
welderman - 20/9/12 at 10:15 PM
I made a couple in the past. Quite easy but very basic. If you want me to make one up give me a shout. I'm stuck for time doing things at the mo. lost of things going on. If you don't mind waiting
