A friend is having problems with his type 9 gearbox. The gearlever no longer has any springing action and can be left wherever you put it.
Any body know most likely cause for this?
there is a circlip under the first rubber boot,if that falls of it will do that
speedy speedy conrod,
might be silly question but what rubber boot? are we talking about the lever shroud?
cheers mate
yup,there are 2/3 rubber boots/shrouds on t gear lever,its the bottom one the clip is under
