Hi Guys I’m after some help if I may.
Trying to wire a customer’s Kitcar.
The engine is a silvertop 1.8 Zetec (March 1994)
He was supplied with a loom and ECU which turn out to be for an efi Pinto so he was seen off there.
He later bought an engine loom and ECU from a Mondeo 2.0 16v 1995-98.
Identity is:- EEC-IV (PATS 1) SME-405 TELL 95BB-12A650-KB which is the 60 pin ECU.
I think it will still work despite it being for a 2 litre.
Now to the problem(s)
1. There is no key or PATS antenna. Is there any way I can make this ECU work or do I have to go find another one?
2. There are a number of ‘Features’ of the ECU I have no use for so can I leave them disconnected or do I need to fool them in some way.
2.1. Road Speed Sensor
2.2. Starter Relay
2.3. EVAP
2.4. Rad Fan Relay
2.5. PAIR Valve
2.6. Data link Connector
2.7. Exhaust Gas Pressure Sensor
2.8. Power Steering Sensor
2.9. EGR
The first 2 are the ones I’m uncertain about. The others I’m pretty sure can just be ignored.
Any help you can give would be great.
Originally posted by steve_dI think it will still work despite it being for a 2 litre.
2.2. Starter Relay
2.3. EVAP
2.4. Rad Fan Relay
2.5. PAIR Valve
2.9. EGR
Hi
Thanks for the answers so far.
I suspected I was going to need another ECU.
Question now is do I just find another 60 pin as I've already modified the loom or bite the bullet and go for the 104 pin version. Are there many
advantages with the 104 pin over the 60 pin?
Anybody got a spare 1.8 ECU, pats and loom they don't want?
The full name for the PAIR valve is 'Pulsed Secondary Air Injection'. It connects to the ECU at pin 14. I believe it is part of the airbox.
If it works the same as motorbikes then it adds air into the exhaust to make sure all the fuel is burnt off. This is normally just at tickover or
light throttle which is just where we need to meet emissions limits.
The wiring is just a part of other work for the customer so I don't have a breakdown of the cost. Your problem will always be that Kitcars are
built because they are a cheap route. Professional services are costly which is galling to the kit builder but is unfortunately necessary if the
builder does not have the skill set, time, incentive etc. to do the work themselves.
I am a big fan of the oem ecu's and really dont see the need for an aftermarket ecu in a road car. Very few people install a bike engine and then
spend money on aftermarket ecu's.
pulsed air, Ah yes I am sure they did away with that on later models as it only operates for around 20 seconds from cold untill the engine is run
closed loop.
They did lots of little things to reduce emissions.
The first one I did.
http://youtu.be/Pxq4ks2Us_U
As to changing ecu, thats only a call you can make. I dont bother with them anymore as I like to be able to see what the ecu is doing.
http://youtu.be/8zXrUmykoAw
my current set up
http://youtu.be/BKqeCjdBM0w
I am now working on the st170 loom.
http://youtu.be/4UMyy6HXvQ4
And yes Locosbuilders are tight as f###k and the standard response is get yourself a megasquirt.
The price I was pitching was a custom manifold with Tb, maf, injectors, ecu a custom loom with obd2 port and sensors not found in the engine block.
Price £300, takers = 0
[Edited on 6/11/12 by big_wasa]
Looks like a fair package.
Customer has now sourced a later (104 pin) ECU and hopefully all the add on bits.
Not having much luck finding 104 pinout info
ECU will be EEC V 2S7A-12A650-AFA SHNO
Does anyone have a list?
Many thanks
Well I hope he did'nt spend much because from my records thats even less use to him than the last one.
That ecu is for a 2001~2007 mk3 mondeo fitted with a 1.8L Duratec.
This ecu is full canbus so missing inputs will trigger the ecu into limp home mode. The duratec fuel and ignition map will be very differant aswell as
all the sensor values.
You will not find the pinouts on the net, You will also not be welcomed on Ford bassed forums asking how the immobilizer works or can be bypassed
So what year can I go up too or how do I identify which ECUs are OK.
Not that easy.
What Tb and other sensors are you using ? If its from a silvertop the same as the engine then you will want a silvertop ecu. upto 1997.
From the list I'm looking at there are no 104 pin ECUs before 1997.
That would mean using the 60 pin which you suggested I should avoid.
It is a 1994 Silver Top but I don't know if the Inlet came with the engine as I am not that familiar with them.
The search goes on.
Upto 96 is eec-iv = 60 pins.
97> is eec-v and they are 104 pin and suport obd2.
Black top zetec's came along in 1998.
Zetecs finished in the mondeo when the mk3 came out in 2001 with the duratec but the focus carried on with the zetec untill 2004 from memory.
The silvertop had an alloy Tb and maf The blactop had a plastic Tb and maf. Just keep the sensors matched to the ecu.
