Hi, I'm making some new engine mounts, as the tiger ones have failed (see photo archive). Just wondering if anyone has some advice, tips, pitfalls to avoid etc...?
Loggyboys post on this thread has some good pics, I will be copying that design too when I get round to it.
http://www.locostbuilders.co.uk/viewthread.php?tid=175965
I was planning on following the Loggyboy design as it doesn't seem to have any obvious weak spots, unlike the tiger ones!
Whlst I would love to claim credit for the design, I merely copied the Raw items, just made them myself for a fraction of the cost!
Originally posted by neilp1
I would just copy the tiger ones, but use heavier plate 6mm as the 3mm plate is way too light.
You could even repair your current tiger ones. Just add a pair of gussets from the piece of tubing on either side of the broken plate. You simply need
to transfer the bending load.
New ones will be easy to make as well. Just add gusset plates in the right places or build it the agricultural way... Thick and heavy.
Originally posted by JF
You could even repair your current tiger ones. Just add a pair of gussets from the piece of tubing on either side of the broken plate. You simply need to transfer the bending load.
SAE rules insist that bolted tubes used for mounting as in this scenario have at least one continuous tube to the point of mounting. They then have a diagram similar to loggyboy's mounts. The majority of the other mounts in that thread look under built and as though they could suffer the same fate as your old one.
Biggest downside of Muzchaps to me is that the tube is left open, so expect some brown stuff over time, but you could blank of the end to counter that. Loggy's design has the about the same thing... open ended tubing. Hard to paint, and this time the open end is up. So any water that makes it's way there will stay there. But then again... how much water will these cars see in their life?![]()
Originally posted by loggyboy
Very easy to powdercoat them, and not hard to paint, the hole is only an inch or so and with a harsher radius could nearly be made non existent. Pop the hood on any tintop and you'll see loads of water/mud traps that cause no issues.
Heres mine...
Cheers for the advice chaps. I would have responded sooner but didn't gat any emails to say there'd been posts!
I've decided to not repair the tiger ones as they're too short, the engine leans and the bloke who build the car used about 1 cm of washers
to prop up one of the rubbers, so I want to do it properly (well try too!)
Good point re a water trap, I think that I'll weld a nut in and have the tube come all the way down to the plate rather that have the upright
tube. So far I've made the plates for the engine block. Tomorrow I'll do the tubes...
Here we go:
New engine mounts, OK the weldings not great, with hindsight I thing the wire speed was too high, that said I think they are strong enough, time will
tell. Deviated from the original design as I didn't was to create a water pool, so have welded the top nut in. Also the reason one of the bottom
plates looks like a dogs dinner is it needed reducing in size to avoid a brake line and I err ahem go a bit carried away without actually looking at
the shape of it, I can cut it to the shape of the rubber underneath (round) as the down tube just goes outside it. So I stopped whist it just looked
dodgy before I cut something off that I needed! Luckily it sits underneath the exhaust / water pump so it's not going to irk me every time
I'm in the engine bay!
More juice required i would say. Lack of fusion
If it was me i'd grind the weld off and reweld after some practise.
You could be right, had the welder at full power, only 100 amp so probably on it's limit, although when I dropped the power down, it didn't
seem to make much difference, hence coming to the conclusion that it must have been wire speed.
Seems pretty solid though...
I had a similar issue on my mounts using a 90amp welder. I ground them back down after the first sweep and went again just to be sure. They seem ok, but like you say only time will tell. If they fail it will be an excuse to buy a better welder!
Here we go:
New engine mounts, OK the weldings not great, with hindsight I thing the wire speed was too high, that said I think they are strong enough, time will tell. Deviated from the original design as I didn't was to create a water pool, so have welded the top nut in. Also the reason one of the bottom plates looks like a dogs dinner is it needed reducing in size to avoid a brake line and I err ahem go a bit carried away without actually looking at the shape of it, I can cut it to the shape of the rubber underneath (round) as the down tube just goes outside it. So I stopped whist it just looked dodgy before I cut something off that I needed! Luckily it sits underneath the exhaust / water pump so it's not going to irk me every time I'm in the engine bay!
Here we go:
What thickness plate have you used there? I am about to make some, with 40mm box and a choice of 3mm plate or 6mm plate - don't know which to go with...
The new design avoids the obvious stress points, heres a couple of pics of the old ones:
and
So I've bought a 150 amp welder, with a view to redoing the mounts. Was using my 100 amp welder today and realised that I hadn't switched into high mode (that's why switching between the 2 high power outputs made no difference!), so I never really used max power grrr so my existing welder may well have been good enough!! Oh well I got a more powerful welder out of it!!!
