What do you think? one of these on both sides, reckon it will be strong Enough?
photo size
pipe to small... 25x25?
[Edited on 11/1/13 by fregis]
What the bleep made that so big lol
yeah its made from 25x25x4mm steel box
you have a lot of bending stress on the engine side of the tube and sharp corners, I'd personally put a small web in there. I've made similar but with 3 inch 3mm wall thickness tube which is a common home made type
would 33x4mm steel pipe be suitable?
If you use a round rubber mount I think it looks better if the plate that bolts to it is also round.
Just my 2p
Paul G
edit to add pic
907 os engine mount
[Edited on 12/1/13 by 907]
I would use 2in (either round or square) purely to get more weld area to take the stress.
I'm going to make a plate that goes onto the rubber, in the picture it is just placed together and only 1 weld has been done as I ran out of gas
