Bike drive idea ?!? thoughts please
tompat3463 - 12/3/13 at 07:02 PM
I will firstly apologise for the quality of my drawing
can any of you see this set up to have any problems.
heres the scenario.
bike engines in the front of a mini make for an extremely short chain thus shortening chain life and possible damage to engine...
so why not turn the engine 180 degrees and use the gearbox sprocket on the engine as a kind of chain tentioner inbetween the diff sprocket and an idler sprocket towards the front of the car.
this would give a longer chain .
the one problem im thinking is that the gearbox sprocket would only be biting on to the chain with maybe 4-5 teeth but I think this could be over come by lowing the engine onto the chain more thus wrapping it around the chain more.
The smaller idler on the front end of the system would be adjustable so you could tension the chain as required.
please let me know your thoughts and please be honest I wont be offended.
thanks Alan
[Edited on 12/3/13 by tompat3463]
imp paul - 12/3/13 at 07:11 PM
looking at the set up i feel it would not work safely, and would jump teeth looks like a bad idea mate but Alan i do believe pro motive did a front diff/ set up you could google it mate
here you go http://www.pro-motive.co.uk/
[Edited on 12/3/13 by imp paul]
adithorp - 12/3/13 at 07:20 PM
You'll need a lot more wrap around the sprocket to prevent it slipping/jumping teeth or a LOT of tension in the chain and that'd make it wear the chain.
MikeRJ - 12/3/13 at 07:22 PM
Won't work, you need to wrap the sprocket far more, especially with a small sprocket. Also you'd have to extend the sprocket out significantly from the bike gearbox, as the engine castings would prevent you running the chain forward like that. That would place a lot of stress on the gearbox output shaft bearing, so you'd probably want to support the sprocket with another external bearing.
One possibility is to make the run with two chains, each sharing part of the overall reduction. This would mean the "small" sprockets doesn't have to be very small anymore which significantly improves chain life.
[Edited on 12/3/13 by MikeRJ]
tompat3463 - 12/3/13 at 07:27 PM
thans for the replies..
the promotive kit is exactly why I though of this as I want it to be as DIY as possible.
I did think the chain would need to be wrapped round more.
MikeRJ i dont think it would make the system run the wrong way as the gearbox sprocket is effectively pulling the chain of the top of the diff sprocket therefore driving the wheels forward. remember the engine is facing the wrong way.
Ill have a remeasure and re draw and see how much 'wrap around' I can get
cheers people
MikeRJ - 12/3/13 at 07:44 PM
Yup, I realised that when I re-read your first post and found you where reversing the direction of the engine as well! Tried to post a pic of a two chain solution, but LCB is behaving very oddly with pictures for me (the first uploaded image links to a completely different picture, if I upload it again with the different name the picture is correct but avatar sized!).
Slimy38 - 12/3/13 at 08:37 PM
If you're wanting to overcome the disadvantage of having such a short chain, can't you do away with the chain altogether and use gear wheels, similar to a FWD car gearbox and diff combo? You'd have to fix the diff to the engine but it might have fewer mechanical and maintenance issues.
tompat3463 - 12/3/13 at 09:09 PM
I was thinking of using gears but I didn't like the fact that they would be open to the elements if u didn't fabricate some sort of enclosure for them. Looking at the engine again it seems my original plan doesn't work either as mentioned above the engine casings foul the chain !
Looks like its going to be a shot chain
cloudy - 12/3/13 at 09:15 PM
I think a short chain is less of an issue than you think - yes they reduce the life of the chain, but the slight increase in running cost is somewhat offset by only having to buy shorter lengths of chain...
The R4 runs sprockets with perhaps 10cm between them, and have only ever needed to replace the chain once (wasn't using a heavy duty chain and the issue was uneven stretch from hard launches rather than wear)
I personally wouldn't worry about it! Just use a good high quality chain with the highest ratings you can find....
James
[Edited on 12/3/13 by cloudy]
