hi guys,
need some advice/help please
i have been out using my turbo sigma kit car done around 120 miles with no issues.
yesterday all was going well then it stopped holding boost and making a sort of whining or slipping noise under load
performance was rubbish, but it selected gears fine, lipped it home and was convinced it was the clutch and i had got something wrong in terms of
clearances.
ive pulled the engine this morning and i dont think it is the clutch it dost look bad and its more than up to the job of the current low boost power
level
where do i need to be looking next?
main boost pipes are fine were tight and are new no holes in them that i can see.
checked the external wastegate diafram and thats fine, blanked the feeds to it and blew down them no leaks there
any ideas what next to try, im due on the rollers friday to finish mapping and need to sort this asap!
i have pics of the clutch etc... and engine setup if anyone thinks they may be of use
thanks
Poss intercooler it self split? I have known it before on other applications.
If it is producing boost still just not holding it then it must be a pipe, waste gate, intercooler, gasket something along those lines
Did you try to load the clutch from a standstill to see if it slipped?
[Edited on 17/3/13 by chicade]
Check for boost leaks using a compressor.
http://www.myturbodiesel.com/1000q/multi/boost-leak-tester-DIY-check.htm
I blew the blanking plugs out of my throttle bodies and it did some of what you describe.
An old innertube is quite useful if you have a compressor and a tyre inflator.
How does that work? Stretched over the hose end?
My plenum split, only noticeable when under pressure.
Waste gate stuck open ?
does the whine start as the compressor spools. it could be a impellar gone out of balance or chipped. or a gasket leak but id expect boost to still be there with that one. First port of call would be a pressure test imo.
I have just changed my plenum as it split on three occasions, as mentioned only visible under pressure. Good place to start looking.
It will need rebuilding yes, is it a cheap Chinese turbo or a known manufacturer? I'd say you have oil feed problems for it to fail that quick. Either not enough oil getting to the turbo or a restricted drain from it.
You would only need a core unit(can't remember the exact name) I have a 2871r .64 on my 200sx and have heard about others with this turbo having similar issues to you but not that quick. I can try to see what restrictor size should be used if you like. What about turbo dynamics
something like that yeah.
I guess its a V band exhaust flange? If not then you can used a standard t28 form an SX. My 2871r has done 20K and still going strong so roller
bearings arent that bad. thats with good few trackdays too.
I guess its a V band exhaust flange? If not then you can used a standard t28 form an SX. My 2871r has done 20K and still going strong so roller bearings arent that bad. thats with good few trackdays too.
Yeah I am, do you not on yours? I spoke to a guy that is a mapper and the bearings are sat on the turbine shaft so that's why they can't be rebuilt.
Yes mine had it, says £550 + vat standard or £700+ if I want upgraded bearings
Going to make water cooling better as car runs hot
Separated rad and pump and run it as its own system
bb turbos need the feed to run with the water system.
jon your right, impellor is catching the housing just had the turbo off
not good really as it has done about 8 hours work since new
not sure of the damage presume will need full rebuild?
blades were fine.
on inspection its overheated due to insufisiant cooling, had issues on dyno with engine throwing a belt and having to kill it hot which meat a hot
shutdown of the turbo with no coolant in the system as it empited itself
new core in order for the turbo and making a improved cooling setup with a secondary water pump that will run after the engine is shut down like
production cars have that have bb turbo's
all in all and expensive mistake somewhere along the lines!
