Pinto help needed.
samjc - 29/3/13 at 09:28 AM
Hi all, it's been a while since ive been on here or in the garage but back again with motivation so here I go, my 1.6 pinto is ready to be fired up but my battery is huge, what rating should I look for to shed weight, will a second hand bike battery work if so again which type and what rating to look for, also I was hoping to make my own hydraulic clutch setup using a defender slave cylinder externaly mounted but the tunnel is far to narrow, what internal ones can I use ie mondeo slave cylinder. As dont like spending a fortune on the rally design one.
Any help grately appreciated
Mikef - 29/3/13 at 09:37 AM
Certainly don't think a bike battery would do the job. I use an odessey PC680. mounted in the passenger side. Nice and light. I do have an Anderson plug connected to it for a quick jump on cold mornings if I need it. Cant help on the clutch.
MikeF
snapper - 29/3/13 at 10:19 AM
If you want light Russ Bist of Furore does gell batteries of different sizes cheaper than most
gavin174 - 29/3/13 at 10:28 AM
as Paul says
if you really want to save weight..
speak to Russ
just started a 2.0 Duratec with a 1.0kg battery.
not done any miles yet, but no problem turning it over
[Edited on 29/3/13 by gavin174]
samjc - 30/3/13 at 09:00 AM
Cheers guys,
Also anyone know what grade oil to use on the ford type9 gearbox ?
