How much propshaft clearance would i need between the prop and the tunnel?
Would 1 1/2inch be enough? - The axle and trailing arms are off a viva/magnum
left right or up down?
it runs to the right as the diff is off center
I would expect a live axles left-right movement to be minimal, so 40mm+ to one side should be fine.
