Hello all,
I am trying to decide which engine to fit, and have got the following options...
Option 1 - Cologne 2.9i V6 - It is fitted in my donor car. The problem is that I'd need a 2WD V6 gearbox.
Q1. What would I do about the injection? is there any way I could use the standard injection and ECU? OR will I need anything else? Throttle bodies
and a management system would be very expensive, and well out of my price range.
Q2. Would I need to change the sump? the 2.9i from the 4x4 has got an alloy sump I believe. can I modify the alloy one?
Option 2 - Pinto, with the idea of upgrading to a zetec after SVA.
I could probably buy a complete pinto engine for less money than the V6 type 9 box that I need for the 2.9 route, and I could probably sell the 2.9
lump for a bit on ebay.
Q3. What is involved in changing from a pinto to a zetec? I'm guessing its a big job.
Q4. how expensive is the management system to run a Zetec? From what I can tell, you cannot use the standard plenum and injection?
What does everyone think? Is there any other options I am forgetting about?
Apologies for all the questions.
Regards,
Chris.
[Edited on 6-10-04 by Chris Green]
Why not straight to Zetec?
Save doing stuff twice and you get a good engine with plenty of power/tuning potential.
If that's not an option then I'd do Pinto to Zetec.
Steve Gusterson has used the 2.4V6 which is the little brother of your one. He's used the standard plenum etc.
Getting a manual gearbox won't be easy but one from a 2.8v6 Capri would fit and I don't think they're that hard to find.
All the best,
James
P.S. AFAIK most people don't use the injection on a Zetec- they fit weber carbs.
[Edited on 6/10/04 by James]
The main reason to go down the pinto route would be cost to be honest James.
I know you can pick up a zetec cheap enough, but how much would it be to set it up on carbs? what ignition would be used for that?
If it was throttle bodies, then the cost is way over my (very small) budget.
Throttle bodies.
They can be picked up reasonably on ebay and along with similarly purchased injectors and a home built MegasquirtnEDIS I think that you may find
something to suit a modest budget.
Colin
My advice is to build the car with the engine you want in it from the outset.
With the V6, you are more than likely going to require two exhaust systems, which means two silencers, and two holes in the side of the body (assuming
'traditional' style).
With the Pinto, you will need to make a hole in the drivers side of the body.
And the replacement Zetec will require a hole in the passenger side...
So with either of the first two options, you will be left with at least one surplus hole in the bodywork. The V6 will may require a change of front
springs (they are quite a heavy old unit).
Of course you want it on the road-but when you are converting it to Zetec, all you will be saying to yourself is "why didnt I build it with one
in the first place???"
Wiring loom mods, cooling system plumbing mods, fabricating new engine mountings, possibly altering chassis to accomodate mountings, new inlet
manifold, another exhaust manifold, modifying throttle cable and clutch cable, defacing your bodywork with extra exhaust holes, or enlarging ones
that dont quite line up now, etc, etc.
It WILL be cheaper in the long run to build with the Zetec to begin with, even though it may take longer to get the car on the road.
A Zetec will run quite sweetly on twin 40's. There are other costs/considerations to bear in mind-worth doing a search for what is required-and
perhaps do the pricing from there.
Remember that there are other engines that could be installed for a similar price too-for example, a 16v VX could be installed for the same money.
Finally, have a serious think about the Pinto as an engine to leave in. A 2 litre motor will give a healthy push, and are easily tunable for a little
outlay. With the budget required to fit a Zetec, you could have a loty of hassle free fun with the Pinto.
Food for thought...
The more I think about it, the more I dislike the idea of the V6. The weight is putting me of tbh, and it doesn't seem to be a common choice.
Perhaps I should just strip the rear axle from my 4x4 donor, and scrap / sell what's left.
How much is a complete 2.9i engine worth roughly?
I'll keep lookout for a zetec, and see what I find. At least I can get started on some of the chassis without one.
Are all the zetec engines the same physically? if not, how can I find out how they differ? I've got some basic sketches of a zetec, and the sump
looks massive, I guess you just shorten it?
A 16v XE would surely cost more, as the engine is more expensive to start with, and a new bellhousing is req'd?
Carbs would be a nice setup for a zetec, but how much would the management be? Is it possibly to use the standard plenum?
oops, sorry about all the questions!
It will cost you twice as much as you expect to get the Zetec running properly.
A bike engine would be cheaper if you can get away with no cat.
If I was doing it again I'd use a 2L pinto with twin 40s and light flywheel. Loads cheaper!
As usual I would say get a drive in cars fitted with the engines you fancy. I would say that a good Pinto correctly set up is a very good option and can't be beaten on price, as long as you don't end up spending loads on a rebuild and tuning to only find that you could have fitted a standard zetec (pre "95 non cat) for the same. The biggest cost difference if you are fitting webers between the two is you will need at least an ignition ECU for the zetec, both will more than likely need a sump chop and alternator brackets.
It can, it's just getting it all to fit under the bonnet, and you end up at least 25bhp down. The standard ECU also needs to be tricked that
it's still living in the donor car with other sensors still connected and poss the alarm. Not sure what the donor ECU is looking for but I know
some have aircon/traction control connections. I seem to remember some people using a basic Escort ECU which may be more basic than a Mondeo one...
It's also far easier to change an aftermarket ECU map with a laptop than the standard Ford item. Also an aftermarket unit will allow adjustable
rev limitor, coolant fan switching and shift light along with real time engine data and data logger output. All sound OTT but are useful.
[Edited on 7/10/04 by zetec]
Megasquirt is easy cheap enough to use on any car , and it even has an EDIS module variant as reported earlier .
a plenum can be made up quite easy to fit a manifold assuming twin 45 manifold or something like it , with one single throttle body at the front or
wherever you like it !
seems simple enough to me .
My build will feature MS from the start - and a motor that doenst have emissions standards!
It can, it's just getting it all to fit under the bonnet, and you end up at least 25bhp down. The standard ECU also needs to be tricked that it's still living in the donor car with other sensors still connected and poss the alarm. Not sure what the donor ECU is looking for but I know some have aircon/traction control connections. I seem to remember some people using a basic Escort ECU which may be more basic than a Mondeo one...
It's also far easier to change an aftermarket ECU map with a laptop than the standard Ford item. Also an aftermarket unit will allow adjustable rev limitor, coolant fan switching and shift light along with real time engine data and data logger output. All sound OTT but are useful.
Originally posted by Chris Green
The performance isn't too critical yet, as even a standard 1.6 zetec would still be quick enough.
Chris.
Originally posted by James
Not for long it won't!![]()
Words of wisdom indeed James![]()
You can have a ride in ours if you want, James
Actually, I haven't been in a V8 one yet. Cheers for the offer!
James
it might be worth having a look at this site www.turbosport.co.uk find main menu then old school, zetec --- seem,s to be quite alot of info regarding r.w.d conversion and parts to use not sure what engine to go for myself anybody know exactly what parts are required to do r,w,d zetec conversion?
Easy option is 1.8 or 2.0 pre "95. There are plenty about from £100 up. Using this engine means you won't need a cat for emissions test on
SVA (unless rules change, but I have not heard of this happening) and will be able to fit carbs if that is what you want. You will need to either
modify a Mondeo sump or some use an Escort one to give more clearance, easy job if you can weld ali. You might need to fit a different water pump (£25
new) depending on the donor car. You will more than likely need to make up a new alternator fixing. The type 9 or MT75 gearbox can be used (same bolt
pattern on the zetec as for Pinto/Crossflow) with a standard Ford clutch, you might want to lighten the flywheel again depending on the donor car. You
will need to get an ignition ECU or ignition/injection ECU if you are not using the Ford one, most people tend to end up using a non Ford aftermarket
ECU as they are more user friendly and easier to set up but more expensive. I'm sure I've left off something but everything has been sorted
for this engine so help is always available on here.
Other smaller capacity zetecs have been fitted but tend to be less common than the 1.8/2.0 units and fitted to later cars so not so SVA friendly.
[Edited on 9/10/04 by zetec]
has anybody got any pictures of modified sump or i have read that 1800 cvh sierra sump will fit has anyone had any experiance with this ta
The first picture on my photo archive shows a modded Dunnel sump, starts life as a Mondeo sump. They also baffle and supply a longer reach pickup pipe.
Easy option is 1.8 or 2.0 pre "95. There are plenty about from £100 up. Using this engine means you won't need a cat for emissions test on SVA (unless rules change, but I have not heard of this happening) and will be able to fit carbs if that is what you want. You will need to either modify a Mondeo sump or some use an Escort one to give more clearance, easy job if you can weld ali. You might need to fit a different water pump (£25 new) depending on the donor car. You will more than likely need to make up a new alternator fixing. The type 9 or MT75 gearbox can be used (same bolt pattern on the zetec as for Pinto/Crossflow) with a standard Ford clutch, you might want to lighten the flywheel again depending on the donor car. You will need to get an ignition ECU or ignition/injection ECU if you are not using the Ford one, most people tend to end up using a non Ford aftermarket ECU as they are more user friendly and easier to set up but more expensive. I'm sure I've left off something but everything has been sorted for this engine so help is always available on here.
10-15 bhp and a bit more torque.
thanks for replying.
I forgot to state that I meant is there any physical difference between the 1.8 and 2.0, and if so, what.
Cheers!
Chris.
No,block is the same as far as I know.
