im going to swap out the engine oil this week before my trackday next weekend. can anyone recommend a decent oil for the 919 fireblade and a rough ammount? i assume a 5 litre tub will be enough but im running an oil cooler up front. cheers
Maybe a Honda bike forum would be a better place to ask the question. You will find more bike engine knowledge there.
maybe, but there are many more on here using fireblade engines in cars.wiyh info and knowledge i trust! cheers
i used silkolene super4 10w40 semi in my old 919 and did lots of trackdays with no issues.
now using a ester synthetic in the R1 engine but that does run a lot hotter with hard track use than the blade ever did.
also bike oil only comes in 4L tubs, may not be enough depending on oil cooler size. get 2 tubs anyway then you have some to top up with, they can use
a little on track. i found i had to usually add a bit at lunch times.
I use Castrol semi synth from Halfords as I have a trade card. Whichever you get Just make sure it doesn't have friction modifiers in as it will
cause slip.
This is the one I use:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_263283_langId_-1_categoryId_165507
thanks guys. got the sikolene,cheers
