I have an interesting challenge question that's kicking around in my head ... Is there a reason why one wouldn't make a aramid (kevlar)
sump, and I'm thinking for a duratec?
I am operating on the following assumptions:
1) aramid outer layers for impact resistance
2) CF / honeycomb inner layer for rigidity
3) choice of epoxy made specifically to not be damaged by exposure to oil
4) this is not for a bike engine, which tend to rely more on conduction cooling
I appreciate that there won't be any thing like as much conduction cooling through the sump, but most people tend to augment the cooling through
an oil-cooler which is active and more efficient.
I struggle to see an issue with this - any thoughts? It could turn out to be way lighter than my current gated sump
Mark
My first thoughts are would it offer enough weight saving over the normal pressed steel or cast alloy item in relation to cost? The money would be
better employed reducing weight higher up the car's CoG IMHO.
I'd imagine you'd need to think about metal inserts to provide a reliable drain plug thread. Possibly for the bolt holes as well to allow
sufficient tightening force without damaging the material.
Pressed steel and cast alloy are pretty easy to modify to suit different installations like a 7 type.
I'm guessing if the OEMs could make them from plastic materials like inlet manifolds they would to save cost (maybe they already do, but
I've not seen one).
With the use of some core materials/Resin Infusion and post cured at a temperature above its normal operating temperature it is certainly possible.
Done right you could see a decent weight saving but it won't be cheap
Sounds like an interesting project. One of those " I said I could do
it " ones. Don't know what experience you have with composites but if I can advise/help at all just let me know.
Regards Warren
[Edited on 3/6/13 by Carbonman]
In addtion to the above weight arguments, even if reinforced, If you clouted a composite sump its going to split... end of, at least with steel one (even alum to a certain extent) its likely to bend first.
Hi Warren
Thanks for the offer. I am about to rebuild my new duratec and have tig welded a gated sump for it (based on the revered flak-monkey design). Whilst
it's certainly up for the job, it's not the lightest. I appreciate that the original duratec sump is light but once you go transverse,
you're either paying £350 for an ally one, or less for a custom steel one with more weight.
My background in composites isn't much that's practical, but I have read a few good books and feel the urge to jump in. My initial start is
to replace the ally riveted on panels on my chassis with CF honeycomb panels, fully bonded in with the appropriate loctite to CF adhesive. This will
give me lots of additional strength for no weight gain.
I got to thinking from there, and about the hassle in making the sump and I thought "it's actually quite a simple shape to mold", and
I've got quite a bit of 3d cad experience so getting a mold cut, or making one from the sump I have may take a bit of time, but won't be
that hard a job.
I'd definitely go for resin infusion (have asked SWMBO for a vacuum pump for fathers day) and a cheap oven to bake a sump isn't difficult to
get.
I can easily see 2-3 kg being saved here, and I'd either buy or have ally hard-points machined for the mating surface.
Thanks for the encouragement. I've also found someone selling a CF rocker cover, but that is way more effort and cost for something that is
already very light.
Originally posted by FuryRebuild
Hi Warren
Thanks for the offer. I am about to rebuild my new duratec and have tig welded a gated sump for it (based on the revered flak-monkey design). Whilst it's certainly up for the job, it's not the lightest. I appreciate that the original duratec sump is light but once you go transverse, you're either paying £350 for an ally one, or less for a custom steel one with more weight.
My background in composites isn't much that's practical, but I have read a few good books and feel the urge to jump in. My initial start is to replace the ally riveted on panels on my chassis with CF honeycomb panels, fully bonded in with the appropriate loctite to CF adhesive. This will give me lots of additional strength for no weight gain.
I got to thinking from there, and about the hassle in making the sump and I thought "it's actually quite a simple shape to mold", and I've got quite a bit of 3d cad experience so getting a mold cut, or making one from the sump I have may take a bit of time, but won't be that hard a job.
I'd definitely go for resin infusion (have asked SWMBO for a vacuum pump for fathers day) and a cheap oven to bake a sump isn't difficult to get.
Thanks for the encouragement. I've also found someone selling a CF rocker cover, but that is way more effort and cost for something that is already very light.
The biggest expense would be labour plug/mould making etc, your time would be free.
As you say with the correct choice of materials it would out perform steel or ally. Push the boundaries, you never know you may be onto something
Hi Warren
If you have the vacuum pump already then I would say go for itThe biggest expense would be labour plug/mould making etc, your time would be free. As you say with the correct choice of materials it would out perform steel or ally. Push the boundaries, you never know you may be onto something
As a follow-up, the raceline ally sump to do this job is £423. It's a sophisticated piece of kit, with removable parts.
I think "watch this space" is in order ...
You could compromise and just do the internals in composites. Epoxy Resin bonds really well to ally. May have to look at any potential issues with
differing rates of expansion though?
There is a product called Soric which is great core material. Once infused it has great compression strength, but very light (little resin uptake)
Doesn't that stuff also act as a channel for the resin to run through?
M
The sump also serves as the only oil cooler, which is the main reason some manufacturers fit alloy sumps on performance models even though they are heavier than the paper thin steel sumps fitted to most modern cars.
I've got an axle for a 1986 ford aerostar van in the garage, and the diff cover is made from some sort of fibre composite. Not sure what exactly,
but it can be done.
The prop shaft also isnt metal, but some sort of plastic and very light. Must be ahead of its time
Hi Loggy - would it though? Aramid is way stronger than steel (as in kevlar bullet proof vests).
M
M
Bullets dont have half a tonne of car propelling them in to the kevlar though, Just a lot of momentum and a few grams of bullet.
Also a kevlar vest isnt isnt designed to retain fluid, its designed to stop the bullet penetrating the body behind the vest, if the vest splits or cracks it will have still stopped the bullet. Those vest also weigh a lot beacuse of the number of layers of kevlar.
To be fair, its quite unlikely you would strike the sump, and then unlikely that you would strike with another force to puncture it. Just one of those 'what if' situations.
M
Originally posted by blakep82
I've got an axle for a 1986 ford aerostar van in the garage, and the diff cover is made from some sort of fibre composite. Not sure what exactly, but it can be done.
Its not carbon, but it has aluminium ends, green and red spiralled banding, and a clear plastic laquer.
I'll get a photo late. Always wondered what it was
The sump may also help strengthen the bottom end, i.e. stopping twisting of the block. No idea if this is relevant to your engine or not but some
bullet sumps are used in this way.. Designing a composite one to do the same would be more difficult.
IMHO you are better off looking at other areas for weight saving; not to say you can't do it but not sure it's worth the hassle..
Dan
carbon prop's have been around for a while - but they arn't cheap![]()
http://www.sevenspeed.co.uk/collections/carbon-fibre/products/caterham-7-composite-propshaft
dig deep!
A mere drop in the ocean!dig deep!
lol
This what it looks like
I have masses of that sort of size carbon filament wound tube kicking about in our factory here in China - I might have to get some of the techs to turn up some end attachments and bond them on! The only problem is, do I trust it...?!
As for the kevlar/carbon sump - I think this has mileage, but don't expect much of a weight saving. Soric is good, but IMHO, not as good for this application as something like this - but of course, it costs more!
Don't underestimate the time and materials to build a mould - if it is a labour of love, then go for it, but there are certainly easier ways to save a modest amount of weight!
If I can be of any assistance, I am happy to do so.![]()
Carbonman - does a sump have any compound curves?! But agreed, it does allow one less consumable to be used, therefore making it easier.
